Future MacBook keyboard could have customizable aluminum keys 📰
Apple is working on how to make a perforated aluminum keyboard chassis with keycaps that incorporate an array of LEDs that can change what is displayed on each key.Apple files all sorts of patents in order to cover its intellectual property and research from potential copycats — even if the technology is never used. Some patents tend to be incredibly vague or difficult to determine until the product is introduced in reality.That mostly describes the latest such filing, anewly-granted patentthat describes a futuristic MacBook keyboard that can change what is displayed on the keys. However, unlike previoustouchscreen keyboardconcepts, this would use physical keys and LEDs to perform the trick.The keyboard would still look like a standard hardware keyboard at a glance. The key casings would be aluminum instead of plastic, and when the MacBook is off, there wouldn’t be any visible markings on the keys.Pressing a key would still actuate a scissor-switch mechanism, so typing would feel similar to existing plastic keyboards used in MacBooks today. However, the keyboard would be made from the same material as the rest of the laptop, enabling a more uniform design, colorway, and rigidity. Note that Apple used aluminum key caps on the PowerBook G4, but those had regular key markings.When the MacBook is turned on, the keys would illuminate. A standard QWERTY keyboard would be displayed, and unlike today’s plastic keys, light would only be visible from the glyph on the key cap. The aluminum key enclosure would have no light bleeding on the key edges.LED backlighting would control what was displayed on each keyIf the user needs to switch to, say, the French AZERTY layout, the keyboard could change to show them exactly that. Or if they simply need a quick way to type symbols, emoji, or punctuation, the keyboard would again be able to change what is displayed on the key cap.Think of it as a physical keyboard functioning like aniPhone’ssoftware keyboard — changing what is shown given the context.This would be accomplished by using a mini-LED, or similar, backlight below the aluminum key plate. Each key would have perforations cut precisely so each LED would shine directly through the top of the key cap.Each key would effectively act as a low-resolution display, showing whatever letter or glyph was needed.This technology is different from using miniature displays for each key like aStream Deck. Nor is the technology, as proposed, able to produce high-resolution imagery like an OLED display or similar.This patent is more closely related to an 8-bit display than a fully-functional display.
