OpenAI has added enhanced integration of ChatGPT with macOS for search, writing, coding, and more. This is what you need to know.In March, OpenAI announced better integration with macOS apps called “Work with Apps on macOS.” The new features work with all tiers of ChatGPT, including the free tier.With the new version (1.2025.057), pressingOption + Spaceor clicking the ChatGPT icon in the menu bar enables ChatGPT to work with running apps. You may also notice a new “Work with Apps” button in the ChatGPT interface in active apps.Work with Apps on macOS integrates withXcodeand third-party IDEs such as Visual Studio Code, JetBrains, Android Studio and more. It also works with macOS Notes, TextEdit, the macOS Terminal, iTerm, Warp, and Panic’s Prompt.After each use, ChatGPT summarizes what it suggested in each app in the main chat interface.Enabling ChatGPT for Visual Studio Code requires installing a VS Code extension to query content.You can view a list of which apps on your Mac are compatible by openingSettings->Work with Apps->Manage Apps.Search results remain in your OpenAI account chat history until you delete them. Once you delete them from your chat history, they remain in OpenAI’s system for thirty days, at which point they are deleted forever.OpenAI has aData Controls pagewhich describes how chat data is stored and deleted.Editing in placeYou can ask ChatGPT to make any code changes in your IDE. If you don’t like what it did, it’s easy to undo with the usual Mac command key combo ofCommand-Zto revert any changes.There’s also the option of asking ChatGPT to suggest changes to code, then you can manually insert the changes.ChatGPT first makes a “diff” in your code for each change, detailing its proposals so you can review and approve changes before it goes ahead and makes them. These new improvements are far easier than cutting and pasting suggested code from ChatGPT into the IDE.You can also tell ChatGPT you only want it to make suggestions for a range of code by selecting it first in your IDE. ChatGPT will then focus only on that selected code block.You can turn off the Works with Apps feature entirely by toggling the “Enable Work with Apps” switch in ChatGPT settings on macOS. This removes the button from the main ChatGPT interface.Voice controlChatGPT also has some improvements to Advanced Voice Control - most notably in opening and selecting apps. However, it still doesn’t yet support code editing via voice control - the feature most developers are waiting for.To use Advanced Voice Control, click theWave iconin the chat bar to start a voice session.The Advanced Voice Control interface when working with apps.Using your data for model trainingOpenAI does state that by default, data saved in your chat history may be used to train OpenAI’s models.You can opt out of this behavior by turning off the “Improve the model for everyone” setting in ChatGPT settings. Doing so prevents OpenAI from using your data for model training.For more information on this, see OpenAI’sData usage for consumer services FAQ.There’s also aTemporary Chatfeature which forces ChatGPT to ignore any previous chat history. This effectively gives you a clean slate to work with.Overall, the new ChatGPT integration features make using it for editing smoother and more seamless. Automatically making changes to code is a big improvement, even if the much-awaited voice editing feature is still in the works.
Editing in place
Voice control
