How to scan & sign documents with Scanner for iPhone
Your iPhone can scan papers, but it’s not always easy to do everything you want with those scans. Scanner is an app that makes it simple to scan, fix, and sign documents all in one place. It’s like having a scanner, editor, and signer in a single app.
Instead of hunting around for different tools, Scanner puts everything you need right at your fingertips.
When you scan a paper with the app, it automatically finds the edges of the page. You can scan many pages at once and make the picture look better with filters. The app can even change the scanned words into typed text (magic!). You can save your scans in the cloud and sign papers without printing them. It’s like having a super smart scanner right in your pocket that keeps your papers safe and easy to find.
Are you tired of piles of paper cluttering your space and worrying about losing important documents?** Scanner for iPhone can help! Turn your messy paperwork into neat digital files. Just scan your documents with your phone and keep them safe in the app. It’s easy to find what you need and protect sensitive information.
How to Scan a Document:
  1. Open the Scanner app on your iPhone.
  2. Tap the “Scan Document” button.
  3. Choose to scan a paper or use a photo.
  4. Line up your phone with the document. The app will automatically find the edges.
  5. Scan all the pages you need.
  6. Adjust the picture as needed (like brightness or cropping).
  7. Save your scan.
Scanner for iPhone offers a free trial to try it out. After that, you can choose a weekly, monthly, or yearly subscription.
