iPhone 16 Camera Control button -- the ultimate guide đź“°
The Camera Control button is a new physical control on the side of the entireiPhone 16lineup. Here’s everything you need to know, and how to get the most out of it.Apple’s Camera Control buttin is both physical and touch sensitive. With a firm press it will click like a real button, but a light-press gives you Taptic feedback like with Apple’sMactrackpads.Subscribe to AppleInsider on YouTubeSubscribe to AppleInsider on YouTubeUsing Camera Control on iPhone 16The Camera Control button starts with that first press. Once you press it, by default, the Camera app opens.Both iPhone 16 and iPhone 16 Pro lines get the Camera ControlWith a second press, it will take a photo or video — depending on the camera mode you have selected.It’s very fast and easy to do. It’s similar to how you could program the Action Button, but more feature-rich and dedicated solely to the camera.Pressing the Camera Control button in the Camera appWhile in the Camera app, you can press and hold on it to start recording a video. If you release, the capture will end unless you hit the record button on-screen.If you light-press the button, you’ll see the screen flex in and a new UI appear. Zoom is default but you can change the control by double light-pressing.There are several controls to pick from when using the Camera Control buttonOn our iPhone 16 Pro, the controls are exposure, depth, zoom, cameras, styles, and tone. Double light-press to open the menu, swipe left and right to choose from, then light-press again to select.Sliding your finger on the screen to zoom when you press the Camera Control buttonWith any control selected, you can again swipe left and right to make adjustments. Like zooming in and out, adjusting the look of the photo, or applying more background bokeh.Sometimes, swiping the button repeatedly is annoying and slow. Like zooming in all the way.The new Camera Control button on the side of the white iPhone 16 ProFortunately, you can slide your finger on-screen too and adjust that Camera Control menu from there without the size limitation of the button.Customizing the Camera Control buttonBy default, the Camera Control button opens Apple’s own stock camera app. Fortunately, Apple has opened this up to developers via a new set of APIs.You can choose which camera app the new Camera Control button launchesThird-party devs can start building this into their own apps and several excellent ones have been updated so far to add support.We’ve tested out Halide, ProCamera, Obscura, Moment Pro Camera, and Instagram. All of which were quickly to adopt it and have varying degrees of features outside of just launching their apps.You can adjust this by:Install and launch any supported apps like those aboveGo to Settings > Camera > Camera ControlChoose another of the available apps from the listFrom this Settings menu you can also assign the button to other camera-related titles, like the QR code scanner or magnifier. Of course, setting it to “nothing” is also an option.You can adjust the firmness of the light-press within accessibilityOne last setting you may want to tweak is the pressure sensitivity. This is found in the Accessibility settings.Adjust the Camera Control pressure sensitivity by:Go to Settings > Accessibility > Camera Control > Light-Press ForceChoose lighter, firmer, or defaultCasesIn a bit of a deja vu moment to last year’s Action Button, many case manufacturers were caught flat-footed in how to design around the Camera Control button.Since the button is touch-sensitive, they can’t cover it the same way they can the other four buttons. Some got info ahead of time from Apple, others gambled on a solution, while others are still reacting.Apple’s silicone cases have a sapphire Camera Control button coverApple, of course, managed to design a cover for its first-party clear and silicone cases. They use a piece of color-matched sapphire on top of a conductive layer to cover the button.Spigen was one of the few that added a Camera Control coverLong-time Apple partner OtterBox has a button cover on some of its cases while Spigen and Supcase guessed right this year. Many of these third-party cases use copper, rather than sapphire like Apple.Many opted to play it safe and leave a bit cutout on the side to remain compatible.Most though have cutouts or holes on the sides of their cases. Depending on the case, this can make the button hard to use, especially on particularly thick cases.
Cases
