Downgrading iOS without losing data is not always guaranteed, even with the “Retain User’s Data While Flashing” option selected. It’s still highly recommended to back up your device before proceeding.
Steps
- Follow steps 1 to 3 from the previous method.
- In the “Easy Flash” menu, select the checkbox “Retain User’s Data While Flashing”.
- Click on “Flash” to begin the downgrading process.
- A pop-up window will appear reminding you that there is a chance of data loss during this process. Click “Yes” if you understand the risk and want to proceed.
- The downgrading process will start. It may take longer than usual (up to 20 minutes) to complete. Do not disconnect your device during this time.
- Once the downgrade is complete, your device will reboot.
Additional Tips
- Ensure you have a stable internet connection throughout the downgrading process.
- Make sure you have enough storage space on your device for the new iOS version.
- Downgrading to a very old iOS version might not be possible due to hardware incompatibility.
By following these steps, you can downgrade your iPhone or iPad to a signed iOS version using 3uTools. Remember that there is a higher chance of data loss when downgrading without creating a backup beforehand.
