Carrier lock iPhones are locked to specific networks. Only those specific network sim cards can work on your phone. Do you want to make your iphone same as like factory unlock? Follow these techniques which will help you to achieve same functionality as the unlocked ones:
- Use JV chips to use any network.
Jv chips are widely available in local market. These chips are used to bypass the network on which your phones are locked and allow you to get access to any network that you desire. These chips are easily available in market which would cost you around 2000-2500 PKR. You just need to insert the chip into your sim card tray and place your sim card above it. Lastly, put back your sim tray in your iPhone and you will get access to the network that you were wishing for. These methods are applicable to models below iPhones 14 pro max as they have got physical sim slot.
Credits: GHOSTEK
- Use Alternate network device.
In contemporary time, there are several devices which can help you to access your desired network. People using Non-Pta and JV iphones tend to buy secondary mobile phones in which they use their sim cards. Instead of buying another phone, you can buy an IKOS device. IKOS are small sim card devices which give you access to your desired network without any hassle. These small devices work with the option of bluetooth. You need to download IKOS app from the AppStore, connect your device through bluetooth with the App and finally you can receive call and messages directly on to your phone.
Credits: Sunsky
If you found this brief blog intriguing and wish to delve deeper into the subject matter, kindly explore our additional blog entries for further insights.
