Image Credit: Fone Arena
You must have observed that the battery of your iPhone is not as good as it used to be. Maybe even your friend, who has an iPhone 15 Series, seems to have this very problem. The battery health generally goes down, but in your case, something has to be done when it suddenly drops from 100% to 95%. Be that as it may, one needs to know it happens with time, and it doesn’t always signify a problem.
Most iPhone users, more so those who are new to Apple, have always been concerned with how to maintain iPhone battery health, this article, therefore, seeks to answer these apprehensions and give tips that will help keep the battery of your iPhone 15 Series in good condition in the long run.
iPhone 15 Series Battery Health: A Normal Decline, Not a Sudden Drop
Is Fast Charging to Blame?
Many users tend to point fingers at the 30W charger as the reason behind their battery health degradation. What’s more, the good news is that iPhones are designed in both software and hardware to manage charging speed, so they actually can handle fast charging without large issues.
Optimized Charging is included by Apple; it does intelligent management of the charging process: Fast charging from 0% to 80%, then it switches to slow charging above 80%. It learns your routine to charge the phone fully when the phone is needed the most and spends less time at 100%.
About Battery Health Decline
Battery health decline is normal over the lifetime of an iPhone. On average, it drops by around 1 percent per month. Some months could stay the same; others might show a bit of a larger drop. Assuming that your iPhone 15 Series is showing 94% battery health after 8 to 9 months, this is rather in order and should not be an issue to raise eyebrows over.
How to Increase the Lifespan of Your iPhone Battery
The battery health usually reaches 80% in an iPhone after two and a half years. Apple has suggested the replacement of the battery to get maximum performance at this stage. For that, you may go to an authorized service center at Apple for the replacement of the original batteries. Other kinds of repairs, like screen replacement, are better done in a trusted repair shop.
This, in turn, keeps the iPhone 15 Series battery healthy if Optimized Charging is turned on, which already controls the charging process efficiently. Never leave your phone in very hot or cold temperatures because these are conditions that damage your battery. Also, do not let it run out all the way too often. Top it off before it reaches those critical levels. You should also be updating your iOS regularly because, at times, battery optimization is added. You can also adjust the screen brightness to save the battery.
Slow Charging vs Fast Charging
While that might seem like the optimal way to keep your battery in the safest state, it’s not very practical. This is why Apple designed Optimized Charging—an intelligent system that balances speed and battery health. Whether you connect via wired or wireless, your iPhone charges with equal efficiency. If it detects the onset of overheating while it’s charging, your device will automatically reduce the charge speed between 0% and 80%.
The Bottom Line
A 6% drop in battery health in about 8 months is just okay. You can go on and continue using your current charging setup and trust the smart features to take good care of your iPhone battery health. Even when your battery health does finally reach 80%, replacement can restore peak performance.
Use your iPhone with complete enjoyment—literally, free of headaches about your battery’s health. Your iPhone is meant to be used and enjoyed. Knowing these things and using the mentioned tips will help you ensure that the battery health of your iPhone 15 Series stays intact and serves for years.
