How to Reset Airpods
  1. Place your AirPods in the charging case, and close the lid. Wait 30 seconds for them to connect to your device.
  2. Open the lid of the charging case.
  3. Forget your AirPods:
  • On your iPhone or iPad, go to Settings > Bluetooth.
  • Find your AirPods in the list and tap the (i) icon next to them.
  • Tap Forget This Device, then confirm by tapping it again.
  1. Reset your AirPods:
  • With the lid of the charging case open, press and hold the setup button on the back of the case for about 15 seconds. The status light will flash amber, then white.
  1. Reconnect your AirPods:
  • With your AirPods in the charging case and the lid open, place them close to your iPhone or iPad.
  • A popup animation will appear on your device screen. Follow the on-screen instructions to complete the pairing process.
Here are some additional resources that you might find helpful:
  • Apple’s support article on resetting AirPods: [Apple airpods reset ON support.apple.com]
  • A YouTube video on how to reset AirPods: [YouTube reset airpods ON youtube.com]
