Using your iPhone:
- Make sure your iPhone and Apple Watch are close together.
- Open the Watch app on your iPhone.
- Tap on My Watch.
- Select All Watches at the top left corner.
- Choose the watch you want to reset by tapping the info button (i) next to it.
- Tap on Unpair Apple Watch.
- Confirm by tapping Unpair [Your Watch Name].
- For cellular models, you’ll be asked to choose whether to Keep or Remove your cellular plan. Choose Keep if you plan to pair the watch with the same iPhone again.
- Enter your Apple ID password to turn off Activation Lock, then tap Unpair.
Using your Apple Watch (without iPhone):
- Place your Apple Watch on its charger. It’s recommended to keep it charging throughout the reset process.
- Open the Settings app on your Apple Watch.
- Navigate to General > Reset.
- Tap on Erase All Content and Settings.
- Enter your passcode when prompted.
Important Notes:
- Erasing your Apple Watch with your iPhone creates a backup of your watch data in iCloud. You can choose to restore from this backup when you set up your watch again.
- Erasing your Apple Watch directly on the watch does not create a backup.
- If you’ve forgotten your Apple Watch passcode, you’ll need to erase it using your iPhone and won’t be able to restore from a backup.
Here are some additional resources that you might find helpful:
- Apple’s official guide on unpairing and erasing your Apple Watch: Unpair and erase your Apple Watch - Apple Support
- A YouTube video walkthrough of the process: [YouTube how to reset apple watch ON youtube.com]
