Following are the Pros and Cons of the Sim Locked/JV iphones:
Pros:
Lower upfront cost: SIM-locked iPhones are often subsidized by carriers, meaning you pay less initially for the device.
Contract benefits: You may get additional perks or discounts on your monthly plan by signing a contract with the carrier.
Network compatibility: A SIM-locked iPhone is guaranteed to work with the carrier’s network it’s locked to, ensuring compatibility and potentially better service quality.
Cons:
Limited flexibility: You’re restricted to using the iPhone with the specific carrier it’s locked to until the contract expires or you unlock it.
International travel issues: Using the phone abroad can be costly due to roaming charges, and unlocking it for international use may incur additional fees.
Resale value: SIM-locked iPhones typically have lower resale value compared to unlocked ones, as they appeal to a smaller pool of potential buyers.
Inconsistency: If you switch carriers or travel frequently, dealing with the limitations of a SIM-locked phone can be inconvenient.
